3 pt. tiller seal
mark from the f
04-24-2007 21:19:56
I picked up a 5 ft. king kutter tiller at an auction--I knew ahead of time it leaked slowly.
I can see it is leaking where the tine shaft enters the gear box. I assume there is a seal--has anyone replace one of these before? If so, an tips? Thanks, Mark
johns48jdb
04-25-2007 19:17:02
 Re: 3 pt. tiller seal in reply to mark from the fort, 04-24-2007 21:19:56
you'll probably find a bad bearing that is letting the shaft drop down. on do-alls years ago we use to tear the bearings out real regular until i took a big washer and welded it just in front of the seal so that flying debry wouldn't knock the cover off the seal leting dirt get into the bearings.
mark from the fort
04-26-2007 07:20:32
 Re: 3 pt. tiller seal in reply to johns48jdb, 04-25-2007 19:17:02
Many thanks--good idea, I was actually contemplating trying to press a second seal next to the first to act as a guard-I like your idea better. Mark
coup
04-26-2007 12:36:42
 Re: 3 pt. tiller seal in reply to mark from the fort, 04-26-2007 07:20:32
new a guy that was so dumb he ran his tiller for a week before finding he should adjust his top link in till the tiller drive shaft ran straight....
El Toro
04-25-2007 04:10:45
Go to www.kingkutter.com/contact.asp and see if they have a repair manual on your tiller. Hal
