Ford offset disc
bfloyd4445
04-24-2007 13:52:49
I have an old, 1975 four gang offset disc that hasn't been used in years but looks in very good condition. My question is, should I take it apart and clean things up regreasing everything or just start using it? It dosen't look like its been greased in twenty years. I know nothing about using discs. In fact I know nothing about anything to do with farming but wish to learn. Any input would be much apprecialted
TomTX
04-25-2007 05:55:00
 Re: Ford offset disc in reply to bfloyd4445, 04-24-2007 13:52:49
You say 4 gangs. Is it an "offset" disk or a "tandem" disk? Tom
bfloyd4445
04-30-2007 06:58:54
 Re: Ford offset disc in reply to TomTX, 04-25-2007 05:55:00
Sorry about that, should have added a pix. Here is a better description. The tool is about seven feet wide in two rows each row slightly bent in the middle kinda like a flattened v shape. Does that help? There are maybe six to eight discs each of the two rows. Sorry for the poor details but the disc is stored 450 miles from my present location and I won't be up there for another week to take a pix. Thank you all for the input
Leroy
04-25-2007 17:15:25
If it is an offset disc then it has to be at least 10 feet or more wide to havs 2 gangs running side by side as one large gang. If it dosent have that then it is a tandem, not an offset.
bfloyd4445
04-30-2007 07:00:54
 Re: Ford offset disc in reply to Leroy, 04-25-2007 17:15:25
maybe it is a tandem then cuase it isn't ten feet wide. two v shaped rows. Thanks
BCnT
04-24-2007 15:47:34
if the disc looks like it was well maintained i'd just grease it good and see what old grease looks like as it squirts out...as long as its not rusty colored you should be good to go...then regrease every 3-4 hours...them old cast bearings will last forever if you keep grease in em.
bfloyd4445
04-30-2007 07:03:15
 Re: Ford offset disc in reply to BCnT, 04-24-2007 15:47:34
Good idea, thanks much. I assume the discs are supposed to turn when you use it and should I put more weight on it to make it dig in better? Sorry for the dumb questions but this is all new to me.
