I am a city boy, moved to the country, have a little acreage and finally got a tractor...something I've wanted for years. It's an older tractor, which is fine as I also like restoring old mechanical stuff. It's an A-C WD45 (1953). I've done the old car/truck restoration stuff, so just natural that a tractor would be a project sooner or later. The tractor seems to run pretty good, so I may just do a refreshing to keep it in working order as much as possible.Ok, now on to implements. I know even less about implements than about tractors, BUT, I'd like to get some to do some basic chores around the home, such as getting a small garden ready for the wife. What implements would be good basic ones to consider? Here are the ones I think would be best, but am interested in other's thoughts on my list. Bush hog - pretty obvious why that would be helpful Box scrapper (to keep the gravel driveway in repair) I already have a corrigator (cultivator?). I was told it was a corrigator, but a friend said it was a cultivator...basically a bar, with about six heavy bars with chisel type (v-shaped) diggers at the end. It sure does a good job of breaking up the soil, but nothing "fine tuned" about it. I'd like to be able to turn up the soil, break up the clods, and then create furrows with raised beds in some cases, and to simply go from rough undisturbed soil, to a nice smooth level ground (such as if putting in a new yard). Those are the two goals I have...what implements would be most appropriate, and why? The tractor has a 3-point hitch (converted I guess from the snap-point hitch). Also thinking about a post-hole digger, and front end loader (trip bucket would be ok), and perhaps a roto-tiller. Since my tractor is older, what is the likelihood that new implements will be compatible with my tractor? What do I need to watch for/watch out for to ensure compatibility? I've seen the term category 1 referred to...what does that mean, and what "category" hitch would I have? Long post, thanks for sticking with me, and thanks in advance for any advice. Rob
