New Holland 1112 Windrower
Rich Griffin
04-22-2007 19:12:06
The engine {Ford in line 6 cyl gas}has a side busted out. Looking for a engine or need to know what other machine may use the same engine. Have tried one from a Owatonna but not the same. Thanks
onefarmer
04-26-2007 08:56:45
 Re: New Holland 1112 Windrower in reply to Rich Griffin, 04-22-2007 19:12:06
It uses a ford 250 engine, so look for old Mavericks or Mustangs
Ford Fan
04-24-2007 18:10:03
As some of you may know, the 250 engine shares the 240/300/SBF bell housing bolt pattern while the 200 CID engine has the "small six" pattern. So if it is a 250 engine, the larger (and more popular) 300 engine would at least bolt up to the machine.
KIP in MX
04-23-2007 16:06:31
If the engine has the intake manifold cast with the head, it is probably a 200 or 250. If it has seperate intake manifold it will be a 240 or 300.
sd pete
04-23-2007 05:39:27
Ford 200 maybe. old Maverick engine i think
RodInNS
04-22-2007 20:08:01
My guess, and it's just a guess, is that it's a Ford 300.... Any junkyard in the country should have them. Install the govenor and necessary parts..... ..... .. and you're off.
Rod
Allan In NE
04-23-2007 04:39:51
 Re: New Holland 1112 Windrower in reply to RodInNS, 04-22-2007 20:08:01
I was under the impression that all those windrowers used the four cylinder engine. Both the gas and diesel versions?
Allan
RodInNS
04-23-2007 08:41:39
 Re: New Holland 1112 Windrower in reply to Allan In NE, 04-23-2007 04:39:51
Allan, I really don't know what they had. You could be right. The fella did say it was a 6 though, so I went with the 300 because I know they used them in the old combines and stuff like that. I know in later years they used the Basildon tractor engines (or the diesel's at least).
I guess in the end, whatever will bolt up in terms of the bellhousing, and make enough torque at low speeds should work. A govenor and controls shouldn't be too hard to add or make up. Heck, I 'magine you could walk a fella right through that with all the work you've done on those 'other' red ones now....
Rod
