New Holland 273
backwoodsfarm
04-20-2007 18:36:59
Was wondering if anyone knows where I could get a used wagon hitch assembly for a New Holland 273 baler? The 268,269,275,276 and 310 have the same hitch.
TMay
04-21-2007 10:26:31
 Re: New Holland 273 in reply to backwoodsfarm, 04-20-2007 18:36:59
I have a 273 also. It had no wagon hitch either. So I made one from a piece of pipe and 3 pieces of 3/8" flat metal. Welded pipe to metal fasten to baler axle with 4 bolts. A flat piece on both sides if axle. then welded the other piece at an angle to the cross piece that runs to bale shute to baler. Sounds complicated but really easy to fix. Pulled wagons with no problems.
MH
04-20-2007 19:16:59
I was looking for one this time last year. Couldn't find one without having to buy the whole baler. Took some pictures of how the factory one mounts & made one. Works pretty good. Probably don't have over 20 bucks in it (had to buy a 7/8" bit for the pin hole in the drawbar)
