horse power needed?
Matt in pa
04-17-2007 16:57:29
I have a 40 hp tractor, what size flail mower and brush hog mower can I use with it. I want as big of mower as I can get. Wich mower would be better for mowing off weeds to prep field for no tilling corn?
johns48jdb
04-19-2007 17:03:20
 Re: horse power needed? in reply to Matt in pa, 04-17-2007 16:57:29
in n al they just over spray and kill everything 4 to 6 weeks before planting and plant away. no mowing required.
Jim Allen
04-18-2007 05:36:03
I also pull a 6-foot Woods behind a 32 PTO hp Ford (2810) and it works fine. Just make sure it has a slip clutch on it. Two years ago I wiped out my PTO using an implement without one. My Woods chopper has one built in but you can buy a unit that slips onto the tractor PTO shaft (Tractor Supply has them) and then you hook the implement driveshaft to that.
old
04-17-2007 18:53:30
40 HP what. Would you believe that a 40 HP oliver will out pull a 40 HP ford. As in I have an Oliver 77 thats rated at 38HP and it will out pull my ford 841 which is 45HP. A lot depends on the tractor and how its set up. As in live PTO etc. etc. etc
amo
04-17-2007 17:37:17
a 6 ft mower would be fine behind a 40 horse, i pull a 6 foor with 32 horses in grass, small brush and weeds. it is a rotary type and does real good.
