Info. on a IHC Plow
HFarmall
04-15-2007 19:21:16
Hi, I don't have a picture, but can anyone help me identify what model this is. It is a 2 Bottom Fast Hitch. It has a leaver that looks like when you take some bolt out you can adjust it from 12" to 14" It also has a big spring that sit on top of the plow frame. I know words are not as good as pictures. Thanks for any info.
Hugh MacKay
04-16-2007 01:54:06
 Re: Info. on a IHC Plow in reply to HFarmall, 04-15-2007 19:21:16
HFarmall: Sounds like one of the early fast hitch plows built at Hamilton ON, very likely a C-25. The lever is a side hill lever, designed to make the left furrow right size, under all conditions. If you look on back side of points, moldboards, etc., do they say ACE?
The cross members between beams are perpendicular overlaping steel about 1" thick allowing the change from 12" to 14" you speak of. The fast hitch forks are very likely the small size for SC, 200 or 230.
