Chisel Plow Depth
Wayne from Wi
04-15-2007 13:27:53
Can someone tell me the reference points to measure the depth a chisel plow is being operated at? I have a JD #712 with 4 inch twisted shovels and it seems to do a good job in our Central Wisconsin soil at about 5 1/2 to 6 MPH, and the depth from the bottom of the trench to the top of the "fluff" is about 12 inches. I have been asked how deep I am operating it and I don't know the answer. Thanks, Wayne
johns48jdb
04-15-2007 16:28:48
 Re: Chisel Plow Depth in reply to Wayne from Wi, 04-15-2007 13:27:53
just curious about how deep should you run a chisel plow. i've only ran a few and were already set when i got to the tractors. we just pulled it as deep as it would go and still move on and not spend a lot of time spinning the tires.
paul
04-15-2007 18:40:46
 Re: Chisel Plow Depth in reply to johns48jdb, 04-15-2007 16:28:48
It's nice to pull up the plow pan that some soils develop from molboard plowing. Typically a plow goes 1/2 as deep as the bottoms are wide, so if a 16" bottom plow has been used, the plow pan will be from 8-10 inches deep. So, nice if you can go 11 inches deep.
Your soil conditions will be different, you might have different goals, but that is 'here'. :)
--->Paul
JMS/MN
04-15-2007 14:22:36
When you lower the teeth to the ground, measure clearancen from ground to frame. Drop it full depth, run at op speed, measure ground to frame clearance. Difference is true depth.
