ID My IHC Plow..
Matthew (Mich)
04-14-2007 11:57:50
Anyone know which model IHC plow I just picked up? I'm thinking it's a little genius #8 but the bottoms have shins where any #8's I've seen just had shares and moldborads. It's a 3-14 because I measured 14" center beam to center beam. Here's a few picture's of it in the implement photo's section. One last thing I would also like to convert it to hydraulic lift. Was there a conversion kit for doing this? I'll get a manual for it once I know what model it is.
Many Thanks
Matthew
georgeky
04-14-2007 12:37:21
 Re: ID My IHC Plow.. in reply to Matthew (Mich), 04-14-2007 11:57:50
I looked at the other photo's and they are not plow chief bottoms. But most plows do have shins.
georgeky
04-14-2007 12:32:46
The one I have does have the hydraulic lift on it. It is a bolt on assembly.
georgeky
04-14-2007 12:27:47
It is a no 8 little genius. It could have plow chief bottoms on it. I have a set with them on it.
Matthew(Mich)
04-14-2007 12:47:24
 Re: ID My IHC Plow.. in reply to georgeky, 04-14-2007 12:27:47
The bottoms can't be plow chief because the share are all one peice. Manybe Super Chiefs???
georgeky
04-14-2007 12:58:25
 Re: ID My IHC Plow.. in reply to Matthew(Mich), 04-14-2007 12:47:24
They could be, but I don't remember what the super chiefs look like. I do remember that they have the throw away shares, but they also have shins on them. Dad has a 531 plow with super chiefs but I haven't used it in 25 years. I have 7 different sets of plows and all of mine are plow chiefs.
Matthew(Mich)
04-14-2007 12:11:23
third party image
I added three pictures of the plow in the community album.
Thanks
Thack
04-14-2007 13:05:45
 Re: ID My IHC Plow.. in reply to Matthew(Mich), 04-14-2007 12:11:23
It's a #8 with Super Chief bottoms. Are the shares 3 or 4 bolt?
Matthew(Mich)
04-14-2007 13:16:33
 Re: ID My IHC Plow.. in reply to Thack, 04-14-2007 13:05:45
I'm pretty sure the share is a 3 hole. Was it a common pratice to put super chief bottoms on as replacements?
Thack
04-14-2007 18:23:19
 Re: ID My IHC Plow.. in reply to Matthew(Mich), 04-14-2007 13:16:33
If the share is the 3 bolt it was also used by MF so you can find them there or from John Deere....but not IH. If 4 hole you can still get them from IH and yes, JD.
It could have been ordered new with SC bottoms, and probably was, but the SC bottom evolved over time. The SC bottoms it probably came with would have been the quick-attach share type and they did not have the replaceable shin. My #8 also has SC bottoms but our parts will not interchange.
I would stay with what you have as you could replace all your parts on all 3 bottoms for what it would cost me to do one. New quick-tach shares are $60.00 each which explains why, to answer your question, yes it was common to replace (older) SC bottoms with (newer) SC bottoms.
So IMO keep what you have including the clutch lift.
