Rotary Tillers
Tanklord
04-13-2007 18:19:58
I need a tiller, preferably 6 ft, would settle for a 5 ft one, to be used with a Ford 5000. Any info, good or bad, about what is available would be appreciated.
chuck davis
04-15-2007 05:51:33
 Re: Rotary Tillers in reply to Tanklord, 04-13-2007 18:19:58
It really depends on how much you plan on using the tiller. If your going to use it once a year for a garden i would probably go KIngkutter.I dont really care for TSC stuff for the most part.
I own a Howard Rotovater and that thing will chew some serious ground,all day long. The bad thing i paid $1500 for it used.5' offset on a D-17 in low range. It has adjustable gear ratios to adapt to the speed of your tractor.I love the thing and use it on my Blueberry farm to control weeds and such.
Chris in MO
04-15-2007 15:16:49
 Re: Howard Rotovator in reply to chuck davis, 04-15-2007 05:51:33
Sounds like a useful piece of equipment. Do you know how to get a hold of the company or where to look for these, used being preferable.
Thank you.
Christopher
ChrisinMO
04-14-2007 20:34:51
 Re: Rotary Tillers soil compaction in reply to Tanklord, 04-13-2007 18:19:58
We use a 5' 3 pt mounted unit and normally use an AC D17 to power it. This sets up a nice 4.5' wide bed for planting.
One problem that I have noticed is the development of a pan just below the tiller level. In the beds where there is plenty of organic matter or where I have recently tilled in leaves, etc., the earthworms, etc. seem to do a good job of correcting this situation. Also, if I till in the fall and then get winter wheat or some such planted right away, the frost over the winter seems to clear this up fairly well by spring. Then if I watch soil conditions and only till lightly enough to work the cover crop into the soil, I have no problems. Where I get problems is with newer soil. I always seem to get compaction no matter what soil conditions are prevalent at the time I till. I am thinking of using a subsoiler or chisel plow on it after tilling to break this layer up.
Anyway, it is easy to overwork the soil when you've got a tractor mounted tiller.
Christopher
Tanklord
04-14-2007 19:31:51
Sounds like King Kutter is the choice. Thanks for all the input!
Redwolf
04-14-2007 05:31:21
Are they all they are cracked up to be? I have a Farmall H and we plant a 40 by 50 garden each year and the soil prep is the worst part of the job. I plow it, disk it, then rototill with a small unit, it and it seems to be a lot of work. Would a 6 footer be too much for my H? How fine does it get the soil? I also would have plans for it to help level and resod around the house, would it be a good first pass prep or would i still have to plow, disk then rototill then level? Thanks in advance.
michael price
04-14-2007 19:47:47
 Re: Rotary Tillers in reply to Redwolf, 04-14-2007 05:31:21
Red wolf, do you have clay? I used to plow disk the til til til. I found now its best to leave it alone since the year before and when its good and dry and hard roto till it and it will powder up the first time.
As for what brand of tiller I would try a king cutter. My dad looked at them and the bought a kuhn for twice the money because he figured you get what you pay for. The kuhn has been great but it was expensive, So far I havnt seen a tore up king cutter and for teh price you cant beat it.
spitz
04-13-2007 18:29:53
Bought ours at TSC. Its a kingkutter brand. So far 3+ years and we are very happy with it. It is a gear drive and seems to be built very well. We run it behind our 2-62white with ease and its a 6foot.
Tx Jim
04-14-2007 04:25:07
 Re: Rotary Tillers in reply to spitz, 04-13-2007 18:29:53
Same here,I have a 6' Kingcutter bought from TSC am I'm pleased with it also. Tx Jim
MF Poor
04-14-2007 05:05:29
 Re: Rotary Tillers in reply to Tx Jim, 04-14-2007 04:25:07
Me three! I"ve owned my KK6"er for 5 years. I"ve used it enough to wear out a set of tines. It is used on a 60hp Deere. Never the first sign of trouble. KK doesn"t have the greatest rep for quality equipment, but that"s not because of their tillers. I"d match it up against any brand at any price. Top it off by being one of the lowest priced tillers on the market and you have a winner.
