Remove Baler Bearing
Leaky Boot
04-12-2007 12:30:34
On non driven roller. Sandwiched between two metal plates. Sealed bearing. I removed the lock collar and outer plate held by the four bolts. Sprayed down with WD 40. Any tips on getting bearing off easy?? Thanks. LB
johns48jdb
04-12-2007 15:46:24
 Re: Remove Baler Bearing in reply to Leaky Boot, 04-12-2007 12:30:34
some bearing on rollers have a locking collar that you put on and twist to make it tighter on the inside bearing race and the you tighten an allen screw to hold that collar in place. if its shot and you have a good little cutting torch i cut the things off. just don't set the baler on fire and cut through into the shaft. a little patience goes a long ways here. you might get it off by heating it and using a puller pull it off ease. cleaning the shaft with emery paper real good before trying to remove it works good. it makes it ease to put the new one on too. some times the ends of the shafts have been hit on and they swell just on the end. i grinder works good here and makes a ease place to start the new bearing back on. don't grind down where the bearing runs, just a little cone put on the end of the shaft is enough.
