Horse power to pull a 3 bottom plow
30 pointer
04-10-2007 16:33:19
How much horse power do i need to pull a 3 bottom plow 3-16. I have a ford 841 will that work? Can a drop one of the bottoms to make it a 2 bottom?
RodInNS
04-10-2007 21:12:57
 Re: Horse power to pull a 3 bottom plow in reply to 30 pointer, 04-10-2007 16:33:19
I've seen (and work) soils where that tractor would struggle to pull 1 x 16 (yes, one), ballasted. Normally, I think 2 x 16 should be OK. I've seen very few places where that tractor would take 3 16's. It's fine for power. IT just doesn't have the traction unless it's got more than standard rubber, and a lot of weight. 3 10's or 3 12's was the number for that tractor. 3 16's is a lot more plow.
Generally, you would be very very close to 20 per bottom with that plow, or at least I am in lighter soil.
Rod
jr150hp
04-10-2007 21:02:39
i have a 1960 841 i have the heavy pieweights and good tires. i can pull 3 14s all day up here in michigan but she like her 2 16s alot better
paul
04-10-2007 19:18:15
Modifying the plow depends upon what model plow you have, as well as trailer, 3pt, or.... Gotta tell us what you have to know if you can drop a bottom off.
In my soils, a Ford 960 (same engine you have, 5-speed tranny) handled a 2-16 real well. It rarely could pull the 3-16. We do have tough clay soils here tho.
--->Paul
30 pointer
04-11-2007 07:31:55
 Re: Horse power to pull a 3 bottom plow in reply to paul, 04-10-2007 19:18:15
The plow is 6000 case 3-16" with spring trips?
paul
04-11-2007 09:29:00
 Re: Horse power to pull a 3 bottom plow in reply to 30 pointer , 04-11-2007 07:31:55
If that is 3 point it is often pretty easy to drop the rear bottom off & make it a 2 bottom.
Some trailer plows the rear bottom is sort of an add-on to a 2 bottom, and can be modified without too much work. Others it is a real machinest dream to re-engineer the whole plow....
I'm not familar with Case.
--->Paul
Hugh MacKay
04-10-2007 17:18:12
30 pointer: Plowing has more to do with traction than horsepower. 15 to 20 horsepower will handle most plow bottoms, question is do you have the weight or traction weight transfer to pull the plow.
It may only require 15 to 20 hp but it will most likely require 2,000# of tractor weight or weight transfer equivalent per bottom.
Josh in Pa
04-10-2007 17:07:39
It all depends on your soil. Here in south eastern PA, 3-16's would probably make a 60 hp tractor grunt. Some plows can have the rear bottom removed pretty easily, and some can't, so its tough to say how hard it will be on your plow. I would think a 2 bottom would work better on your tractor, probably do a nicer job without overworking the tractor. I always thought it was a more pleasant job when the tractor pulled the plow easy.
Josh
