Coulter size - S-KO-20
Ford850
04-09-2007 12:47:48
What size coulter blade was originally on the Ferguson or Dearborn S-KO-20 spring cultivator?
Tom-Pa
04-10-2007 15:04:38
 Re: Coulter size - S-KO-20 in reply to Ford850, 04-09-2007 12:47:48
The Ferguson S-KO-20 did not use the rolling coulter. It had a guide fin the kept the cultivator in line with the tractor. The rolling coulter did not show up on the cultivator until after the break between Ferguson and Ford. It came out on the Dearborn equipment as a way to make it look different from the Ferguson equipment and circumvent Ferguson patents.
ref: Ford Tractor Implements by C. Peterson and Rod Beamer Chapter 6 page 61
Hope this helps
Tom-Pa
Ford850
04-11-2007 07:15:17
 Re: Coulter size - S-KO-20 in reply to Tom-Pa, 04-10-2007 15:04:38
My mistake. I found the tag and I think it is a Dearborn 13-2. I'm not sure if I can get the bolts cut off the hub of the coulter. The hub is sloppy on the cross bolt/axle too.I'd like to get the coulter back in working order, but it doesn't have to be original.
Scott PA
04-09-2007 18:00:17
18 inch.
Ford850
04-10-2007 05:46:39
 Re: Coulter size - S-KO-20 in reply to Scott PA, 04-09-2007 18:00:17
Is there a source for these coulters, and the hub or bearings?
Thanks
Scott PA
04-10-2007 17:47:04
 Re: Coulter size - S-KO-20 in reply to Ford850, 04-10-2007 05:46:39
Click on send email and let me know if you have any of the parts for the coulter now and I can give you some info.
Ford850
04-14-2007 04:11:55
 Re: Coulter size - S-KO-20 in reply to Scott PA, 04-10-2007 17:47:04
I sent you an email
Thanks
