2 Pt Bush Bog
Big un
04-08-2007 09:14:08
Howdy fellers.I have got a 330 Ut that I would love to have a 2 point bush hog for. 5ft or 6ft would work.I already have a 6'pull type.Did they ever make such a thing? I am having no luck finding any info on the idea.Any help as always is greatly appreciated.
Thanks
Bigun
RayP(MI)
04-10-2007 18:00:32
 Re: 2 Pt Bush Bog in reply to Big un, 04-08-2007 09:14:08
Several ways to adapt 2pt to 3pt. I have a worksaver.com unit for my Farmall 200. Use it on numerous impliments. Only problem is making sure 3pt impliment is proper width to fit 2 pt adapter arms, or can be shimmed to fit.
souNdguy
04-09-2007 08:31:16
I know JD made some semi-mounts in 10' area.... not sure if they go down to that 5/6' size though..
Soundguy
georgeky
04-08-2007 17:22:15
I don't know about now, but Bushhog use to make one for a fast hitch. I saw a new one point mower at a sale in January, but don't know what kind it was. It was yellow maybe a Woods. You can put fast hitch prongs on a Bushhog. The fast hitch and three point were the same with different hitch mounted on them.
Allfarmall
04-08-2007 11:53:05
i have a 1958 350U with a front loader, two point hitch and the brush hog that you are looking for. the 350 had a knock and lost oil pressure, so i assume the engine is shot,, cant decide what to do with it,, expense to rebuild engine would match the price for another 350. I dont know your situation but maybe we could work out some kind of trade or other deal. I really need the loader and mower but without the 350 i"m stuck.. Not sure what we can work out, will send you pix of my setup if you would like. mower worked well for me,nice unit.. I"m in northwest new jersey near west end of route 78. Where are you located. John Shaffer
Big un
04-08-2007 13:12:50
 Re: 2 Pt Bush Bog in reply to Allfarmall, 04-08-2007 11:53:05
Allfarmall, I'm quite a long ways from you.I'm all the way down here in AL.Wish I was closer I would sure try to work something out with you.
Thanks
Bigun
Big un
04-08-2007 09:15:18
Should be bush hog not bog.Sorry.
big jt
04-08-2007 10:15:50
 Re: 2 Pt Bush Bog in reply to Big un, 04-08-2007 09:15:18
Yep they made them. IH had one and there may be some others. good luck they are hard to find, especially in good shape.
jt
Tx Jim
04-09-2007 03:58:29
 Re: 2 Pt Bush Bog in reply to big jt, 04-08-2007 10:15:50
My neighbor has one that been sitting for years as he traded in his IHC 300 and equipment stayed. Also has disk harrow,field cult. and 2 disk breaking plow. All of it 2 point and just sitting. Tx Jim
