JD 3 bottom plow
eshoreboy
04-07-2007 19:18:03
I am working on a 3 bottom plow(i dont know that much about plows, i am olny 14 and are gettin into old macheniry) but anyway it was John Deere On every Plow and says sayarcuse(spelling?) on each plow too it has spoked rims. I just need some parts for this plow, can any one tell me about this plow is i give more info and whats the best plce to get parts.
Thanks
Ryan
Leroy
04-09-2007 19:07:17
 Re: JD 3 bottom plow in reply to eshoreboy, 04-07-2007 19:18:03
That is a type of bottom, on the plow model if you can give me some information I can tell you the model no. First are the beams all 1 piece cast or are they made out of like large pieces of flat iron? The cast would be a No. 5, the flat iron could be either a 55 or 55ABH. If the later does it have a square bar going from front beam to back beam and if it does, does it lay flat ar stand on a corner? will tell model by that.
eshoreboy
04-08-2007 17:38:37
thanks its a trip with a rope, yea i want to get my 50 M up for pulling, i live neer a JD delear its about 10 min from me so ill go there and ask, aslo i have 2 busted up rms that cant be fixed would JD have the rims or would i have to get em from the Junkyard.
Leroy
04-08-2007 09:27:39
Also check the No. 5 plow, the older the plow the more likely to have those bottoms and the No. 5 was before the No. 55 and the 55 ABH followed the 55
johns48jdb
04-08-2007 05:54:49
if you have a local jd dealer pick an older parts guy to get you a book and let you look at the pictures in it and you can probably tell you what have. is it hydrualic lift or trip with a rope? i think you might want to start looking at a 55 plow parts book, but just guessing. glad to see your getting into the hobby and especailly into equiptment restoration. do you have a tractor your going to restore to pull it with? you'll find a lot of sharp people (not me) on this site who are great at helping people, especially younger guys. good luck
