Vermeer 503I Baler
Shovelman
04-05-2007 17:00:40
I am looking for opinions on the Vermeer 503I round baler. Any inherent problems, other than the narrow pickup? Will it handle high moisture (silage) hay? What is one in decent condition worth?
Any help will be appreciated.
Hay DR
04-05-2007 20:05:03
 Re: Vermeer 503I Baler in reply to Shovelman, 04-05-2007 17:00:40
The 503I will handle 200 or less bales a year of haylage but you will need: rubber mounted teeth, advance the pickup timing, add 2 rubber flaps to the square starter roller, install bale restrictors, and adjust the wind guard down 1" below the top of the pick-up teeth.
3'x4' haylage bales will be the maximum size you should bale with a 503I.
Shovelman
04-07-2007 05:38:26
 Re: Vermeer 503I Baler in reply to Hay DR, 04-05-2007 20:05:03
Thanks for the reply. Any idea on what this model is worth?
Scott
Hay DR
04-07-2007 05:55:18
 Re: Vermeer 503I Baler in reply to Shovelman, 04-07-2007 05:38:26
These balers usually sell in the $3,500-$4,500 area for the mid-south region.
Shovelman
04-08-2007 17:43:26
 Re: Vermeer 503I Baler in reply to Hay DR, 04-07-2007 05:55:18
Thanks, DR.
Appreciate the help.
