case sp swather
jms
04-05-2007 00:44:18
There is a case self propelled swather coming up at auction this weekend what do you all think about these old swathers it should go for less than $1000.00 would a haybine or hydroswing be better I will be using it on alfalfa ang native
grass
`Bernie in MA
04-05-2007 17:59:38
 Re: case sp swather in reply to jms, 04-05-2007 00:44:18
I've been using a Hesston 110 SP since 1973. I'm on my second one that's 40 years old this year. There are six different belts and all but one require a shaft to be moved out of the way in order to change it. In spite of the maintainance to keep it running I wouldn't mow with anything else. With the stubb guards it hardly ever plugs and ever rarer winds up on the crusher rolls. Less than one time in 35 acres. Just make sure you keep an extinguisher on board. I lost $300 of new belts plus the time installing them when the engine caught fire.
Coloken
04-05-2007 06:27:43
Think Case means same as Heston. If draper platform, check the bearings on the draper rollers. They tend to get water in them.
bradley martin
04-05-2007 03:09:38
If you are just going to be using it to cut hay, get a haybine. It will do a better /faster job of cuttting and conditioning. However, if you also have grain to swath, the swather will do both jobs.
