Lustran planter plate for John Deere
Sandfield Farme
04-04-2007 18:15:48
Where can i find BO30-24 plate with BFR2 backer ring? I need six each of these? Lincoln Ag does not list this plate or the filler ring. Thanks
Brendon
04-06-2007 09:49:16
 Re: Lustran planter plate for John Deere in reply to Sandfield Farmer, 04-04-2007 18:15:48
The plate and filler you are refering to can be found under the "Sunflower Plates" link on the Lincoln Ag Products website. They are priced at $11.50 each.
http://www.lincolnagproducts.com/dbpage.asp?page=sun
LA in Wi.
04-06-2007 06:01:09
What are you trying to plant? For corn, the plate that you are referring to is a B0-24 ("B" fits JD, AC and a few others, "C" is for IHC, Case and some others). BO is for large rounds. There is no need for a backer or filler ring if you are using the proper corn plates.
MF Poor
04-05-2007 03:50:59
What is that? Milo plate?
Sandfield Farmer
04-05-2007 05:20:23
 Re: Lustran planter plate for John Deere in reply to MF Poor, 04-05-2007 03:50:59
no it appears to be a corn plate about the same size as a b-11 but thinner. Thanks
BCnT
04-04-2007 18:36:31
i saw some on ebay other nite...not sure about the number but i saw Lustran JD plates
