411 new holland discbine
L.B. in NC
04-02-2007 14:50:13
I was just wondering if anyone has any feedback on these machines. I have a 7610s new holland and was wondering if it would pull this machine and how reliable they are. The old haybine is getting rough. What is a good used one worth? Thanks in advance.
Henry McMillan
04-06-2007 07:27:32
 Re: 411 new holland discbine in reply to L.B. in NC, 04-02-2007 14:50:13
Do you need a parts unit?
Henry McMillan
04-17-2007 10:48:02
 Re: 411 new holland discbine in reply to Henry McMillan, 04-06-2007 07:27:32
Campobello, SC (e-mail:[email protected])
agman
04-17-2007 07:48:23
Yes, where are you at?
MPeters
04-02-2007 18:07:00
RickB
04-02-2007 17:19:06
A 7610S should run a 411 OK, it won't run away with it on hills or in a big crop. Any 411 you find is at least 12 years old; some will be good, many are worn out. One thing to check that is easily overlooked is the secondary (long) PTO shaft. Check for sloppy telescoping splines and shaft straightness. A worn-out secondary shaft can shake an otherwise sound machine to pieces.
