Hydraulic third arm
Farmer N
04-01-2007 16:37:08
Where can I find a hydraulic cylinder to replace my third arm on my 3pt. hitch?
johns48jdb
04-02-2007 19:28:29
 Re: Hydraulic third arm in reply to Farmer N, 04-01-2007 16:37:08
you need to be careful using a cylinder for a third arm. if you use a cylinder for a third arm you need to limit the amount of sway that your life arms have. the cylinders don"t have enough of romm to pivot much and if put in a big bind they could cause you to break something either the cylinder or the mounting point on the tractor. put one on and move the lift arms by hand and see if everything clears ok. i broke the ears off of a cylinder on my 574 trying to do what you trying to do.
paul
04-02-2007 09:02:43
Hard to post links here, they don't like compitition, but see if I can say Carter & Carter from the mid-south has them, good price. A web search should find them for you. These have high-pressure pilot valves so they will not drop on you over time or in a hose blow-out.
--->Paul
Joe(TX)
04-01-2007 21:02:38
Try Surplus Center
Gerald J.
04-01-2007 18:57:53
Baum Hydraulics, www.baumhydraulics.com
Shoup www.shoupparts.com
Likely Sloan Express, www.sloanex.com
Gerald J.
J Plunkett
04-01-2007 18:57:46
Deere has them or go to woodsonline and look under
Gannon they have third link cylinders
BarryfromIA
04-01-2007 19:22:54
 Re: Hydraulic third arm in reply to J Plunkett, 04-01-2007 18:57:46
Any Prince Hydraulics distributer can order one for you. This item may be in stock at the Prince warehouse.
