Hydraulic Oil for JD 30 Thrower?
Kerwin
04-01-2007 13:21:39
What type of hydraulic oil should be run in a JD 30 thrower? My owner's manual says a "Type 303"--Will JD Trans-Hydraulic work?
Oil types change over time, so I didn't know if the current JD hydraulic oil would include whatever is special about the type 303. Thanks for the help.
Shovelman
04-01-2007 17:37:14
 Re: Hydraulic Oil for JD 30 Thrower? in reply to Kerwin, 04-01-2007 13:21:39
Kerwin,
Type 303 oil is an old JD spec for Universal Tractor Fluid. It was replaced by JD Hy-gard.
We use Castrol UTF in our thrower. It meets the old Type 303 and J-20A specs.
Scott
El Toro
04-01-2007 14:25:27
I thought they would use JD's HyGard. Hal
