NH 256 rake
Devin Sparks
03-30-2007 16:44:33
Hello,
In need of some help.While I was greasing up the rake today I found that the seals for the crank case have gone bad. All the grease I put in came back out. Finally got it apart. Will get new seals and bearings tommorow. Does any one have a exploded view of how everything goes back together. I tried to keep thing together but aftre cleaning parts i dont know what goes where. Any help would be great.
Thanks ,Devin
Shovelman
03-31-2007 15:17:28
 Re: NH 256 rake in reply to Devin Sparks, 03-30-2007 16:44:33
Devin,
A bit more advice: once you have the gearbox assembled, don"t bother refilling it with gear oil. Before you put the cover back on, just push 2 tubes of grease into it and you are good to go.
Grease does a better job in this application and won"t leak out like the oil.
Scott
paul
04-01-2007 12:53:01
 Re: NH 256 rake in reply to Shovelman, 03-31-2007 15:17:28
I believe that is the offial update from NH as well - use heavy grease in there. Forget the original gear oil idea.
--->Paul
Shovelman
03-31-2007 15:21:15
PS: Be sure to pack the bearings with grease before assembly if you decide to use grease in the gearbox.
BigMarv1085
03-30-2007 18:18:54
If you are getting your parts from CNH, they will print you a copy of the parts breakdown.
Devin Sparks
03-30-2007 18:22:53
 Re: NH 256 rake in reply to BigMarv1085, 03-30-2007 18:18:54
Thanks for the reply. I had thought about that. After all I have my big tractor there in the shop. They have always been good about offering help.
e
03-30-2007 18:56:35
 Re: NH 256 rake in reply to Devin Sparks, 03-30-2007 18:22:53
Heck, why bother them. New holland now has the exploded views online. Check it out. Just punch in your model number and bingo.
John Deere took it one step further and you can now find out how much your parts are, order your parts online and your dealer will call you when they are in. Super slick.
cannonball
03-31-2007 06:25:37
 Re: NH 256 rake in reply to e, 03-30-2007 18:56:35
that did not work for me...can you put site down please...thanks
e
03-31-2007 07:37:44
 Re: NH 256 rake in reply to cannonball, 03-31-2007 06:25:37
Try this link, but if it doesn't work, go to the new holland North American home page. Click on parts & service. Then click "search for parts." Type in your model number and it will give you several options for 256, one being your rake.
cannonball
04-01-2007 05:21:24
 Re: NH 256 rake in reply to e, 03-31-2007 07:37:44
That worked THANKS..
MAY GOD BLESS THE USA
e
04-01-2007 08:11:14
 Re: NH 256 rake in reply to cannonball, 04-01-2007 05:21:24
Ain't technology great when it works!
MikeinKy
03-30-2007 18:09:30
Last year I had to rebuild the box on my 56 and the dealer made me a copy from his parts book. Most of them are pretty good about that.
Devin Sparks
04-01-2007 05:30:31
 Re: NH 256 rake in reply to MikeinKy, 03-30-2007 18:09:30
Thank you all for your replts. I made a copy when I pickeup my parts.
Devin
