JD model 14T hay baler, worth getting?
Jed
03-13-2000 20:13:26
I could use a small bale baler and have the opportunity to get a John Deere model 14T for free. The baler, supposedly, was running OK when parked 4-5 years ago. Is this model prone to problems or would it be a good worker with a little work put into it?
Thanks for the help in advance.
Jed (newbie in Utah)
mechanic
03-14-2000 15:29:23
 Re: JD model 14T hay baler, worth getting? in reply to Jed , 03-13-2000 20:13:26
I would say just soak the knotters in oil and all the chains and make sure it is properly greased before you hook it up to a tractor.And its a good idea you can turn it over bye hand before you put it on the pto.I would have to say from what ive seen and heard the 14t Was probably the best longest lasting baler ever made.And ive never even used one.
B.C.
03-14-2000 06:35:10
For sure, get a manual and parts book from any Deere farm equipment dealer. Like the others said, grease her up well. Be sure the knotter knives and the plunger knife are sharp and in alignment, and that the baler itself is in time. The book will tell you all of that.
Obtain a quantity of shear pins for the flywheel, at least while you're learning. Always use fresh twine, and be sure the porcelin guides don't have grooves worn in them. Replace them if they do.
While I am a New Holland man, I have to admit the 14T I used to have did a good job. Getting parts was no problem, and we didn't need that many anyway.
Be careful when you rake for it, to keep the windrows uniform.
If it's all there and you prep it correctly it'll be a good machine. Just remember there is a limit to how much hay you can shove through it.
Haybaler
03-14-2000 14:17:09
 Re: Re: JD model 14T hay baler, worth getting? in reply to B.C., 03-14-2000 06:35:10
AMEN on the limit to shove thru!!!!!
Tim(nj)
03-13-2000 20:47:01
Was it parked inside, or left outside? Moisture and balers do not go well together. Give it a try, but be prepared. You'll definitely need a manual. Time and patience won't hurt. Don't wait until right before you need it to troubleshoot it. You may end up spending several weeks on it, or you may have it running like a clock in a couple of hours. From similar experiences, it's hard to tell what all a machine will need until you've gotten it home and torn into it.
Haybaler
03-14-2000 05:46:39
 Re: Re: JD model 14T hay baler, worth getting? in reply to Tim(nj), 03-13-2000 20:47:01
Man if you dont' want it I'll take it!!! Seriously all I can add is follow the manual religously, Tim(nj) hit it right on the head. Soak the knotter assembly in penetrating oil and it will help alot. This board has a lot of people with haybalers (especially 14T) and everyone is always ready to help.
Leon
03-14-2000 14:34:15
 Re: Re: Re: JD model 14T hay baler, worth getting? in reply to Haybaler, 03-14-2000 05:46:39
I have had one for quite a few years now. They are a very good baler. I learned from an old John Deere man several years ago that when they get worn out they have a tendency to bend needles and shear pins more easily even when properly timed by the book. Mine did this until he told me to disconnect the main drive chain and advance the PLUNGERHEAD by turning it by hand exactly one cog on the chain and then reconnecting it. You can then "shove a lot" into it and it will just keep on balin' no problem! It takes up for wear in the baler. Just thought you all would like to know.... Leon from Mn.
helene gauthier
12-03-2003 12:36:31
 Re: Re: Re: Re: JD model 14T hay baler, worth get in reply to Leon, 03-14-2000 14:34:15
Hi,
I want to know what is exactly the plungerhead in a hay baler? I have to define it. Thank you!
Haybaler
03-14-2000 16:57:32
 Re: Re: Re: Re: JD model 14T hay baler, worth getting? in reply to Leon, 03-14-2000 14:34:15
Hey Leon I may try that on mine. Mine bales good but I have to be careful and not overfeed it. Did it one time too many and it was NOT PRETTY. Thanx.
Leon
03-14-2000 17:49:55
 Re: Re: Re: Re: Re: JD model 14T hay baler, worth getting? in reply to Haybaler, 03-14-2000 16:57:32
Hey (or hay) Haybaler, been there, done that too! The whole baler seemed to run smoother after tinkering with it like the old Deere mechanic said to do. You might want to put a block of wood or something under the raker arm or teeth to prevent them from moving when you disconnect the main drive chain. Any questions you can just E mail me for details. It's very simple to do. Leon
tim[in]
04-09-2000 01:58:06
 Re: Re: Re: Re: Re: Re: JD model 14T hay baler, worth getting? in reply to Leon, 03-14-2000 17:49:55
definitly get plenty of shear pins !! lol this baler can tell you the what moisture the hay is! mine would not tie a couple of bales then go on to tie the rest just fine then do it again later just to make sure i wasnt getting to relaxed !!if you can kep it tieing and not shearing too many pins then you've got it made ! i would clean out the baling chamber and make sure it isnt rusty and the chute isnt broken.
