JD 44 plow question
riverbend
03-26-2007 19:58:09
I have a trip lift JD 44 plow and the depth lever is starting to 'slip'. Sometimes it is fine, but once in a while it will drop down a few notches went I drop it. Anyone else had trouble with this ? Do you remember what the fix was ?
Thanks
Greg
ET
03-27-2007 04:59:14
 Re: JD 44 plow question in reply to riverbend, 03-26-2007 19:58:09
It sounds like you need a new spring on the lever that holds the dog in the notch. Are the notches worn at an angle or taper? If they are build them up with a welder.
