I think the mud is part of the reason we use the points instead of sweeps, but in the past the machine would be just as wide as the dualed up 285 so you couldn't get very close anyway without risking getting stuck. That was pulling a 14' or so Glencoe with a 2 bar harrow on the back. The 18' spring tooth we have now is a little wider than our dualed up 1855, and has a harrow on the back, but it's not very good and the whole angle iron is what does most of the smoothing, not the teeth welded to the angle. For weeds, the only one we really have much trouble with is quack at times, so a point rips it out better than a sweep in our area too. We hardly ever use the disk, unless it was spring/summer plowed after 1st crop. Even then we don't like to disk much. It just cuts up the quack roots and makes it come back even stronger. I gotta go on Thursday to return a carb kit I got for my 1600 (cranked it once more before taking the carb off, and sure as the sun was shining it popped right off... as opposed to last weekend when I needed it and it just refused to start...) Figure I'll take Dad with me and we can both kick the tires, do a little jaw jacking, and decide if it's really worth much, or if it's just another worn out machine. I'll have to watch the auctions, there is a FFA consignment auction in the same town as the dealer the last Saturday in April, they have some good stuff and some bad stuff. We got a 24' spike tooth there for around $100, then we sold our smaller, worn out 20 footer(same make) on the road for $150 to a developer... My dad got that one at auction a couple years earlier (maybe $135) and while it worked, it would have cost us a good chunk just to replace all the bad teeth. 2 or 3 years ago I got another Glencoe with manual wings, think it's a 16'er, for $100 from a local auction. Good points, no harrow, no paint. It hadn't been used since the guy retired about 15 years earlier, and it sat in a dirt floor shed, along with everything else. Everything on the auction was pretty rusty, but nothing was rusted through. We came out of the auction with a small gravity box, the Glencoe, and a Kools blower for about $250.
I just wanna know where everyone is finding these 18-20' machines so cheep, and if they see a decent one within a towable (maybe 100 miles max) distance I wouldn't mind hearing about it... Donovan from Wisconsin
