Need a couple parts to restore BL Case plow
Farmer Jack
03-24-2007 18:51:46
Need some parts which support the hitch on a Case BL tractor plow. Two of the parts I can fabricate if someone has a BL from which they can take measurements. Need the angle iron bracket through which the threaded rod hooks, the threaded rod, the cast crank handle and the plate on the plow frame which supports the crank end of the threaded rod.
Thanks
