Disc Blade Help
warreninwisc
03-23-2007 19:28:40
I have a 12 foot wheel disc, hydraulic lift, that I need to find replacement blades for. It looks like the original blades were probably about 18". The problem I have is that the replacement blades I can find all have either square or round axles. My disc has a 1" hexagonal shaft. I can not find any type of ID on this disc. The color makes me think it could be an Allis Chalmers, but I really have no idea. Where do I find replacement blades for this beast?
Thanks
Dave Anderson
03-24-2007 16:41:46
 Re: Disc Blade Help in reply to warreninwisc, 03-23-2007 19:28:40
Probably is an Allis, they used hex shafts. Just measure the shaft diagonally across the points of the hex, and order the closest round shaft disc blade that will fit over the hex points. the key thing to do is to keep the gangs tight, and you won't have any problems.
super99
03-24-2007 03:31:08
Try Agri Supply. 1/800/345/0169 www.AGRI-SUPPLY.com
They are in Carolina's and Verginny, shipping might be prohibitive but their catalog shows lots of blades but not sure about hex holes. Chris
