Seed Flow 2
nates90
03-22-2007 08:14:48
Hi guys...I just bought a ih 800 planter and it came with a seed flow 2 monitor....and what i was wondering is, when i hooked it up without the planter it did a test and failed it (of course) and went through 16 rows...then i hooked it up to planter and it still failed (dont know why) and it only went through 6 rows (thats how many the planter has). What i was wondering it had a sensor on position of the planter...if it is in the ground or not. I was just wondering if there was a common thing that makes the test fail. The guy said he took it to Case IH and had it tested, so i dont know.
thanks,
-Nathan-
paul
03-22-2007 08:43:16
 Re: Seed Flow 2 in reply to nates90, 03-22-2007 08:14:48
I have a diff brand of monitor, so this is only general, and maybe even wrong.... ;)
In or out of ground should not matter.
My monitor you need to set it to the # of rows, and their width with some switch settings. If it was tested by itself perhaps it got set to max rows, and needs to be set back to 6?
Ground wire is most often the problem, as well as any connection - if there is a 'real' problem.
As well, any spider web or the like over a seed tube sensor.
--->Paul
