Foam Markers
super99
03-21-2007 15:21:34
Has anyone made their own foam markers for a sprayer? I have 62 acres of notill bean stubble that I'll need to spray with roundup for burndown before planting. I have a sprayer and find it hard to pay someone else to spray when I could do it myself and get chemicals cheaper than they charge. Or anyone know where there is a used one for sale? Just wondering, Chris
Greasey Hand
04-22-2007 16:50:09
 Re: Foam Markers in reply to super99, 03-21-2007 15:21:34
I made mine, If you want The plans & pix,
E Me [email protected]
Dave Anderson
03-22-2007 14:35:34
There is a company, Richway or something like that that makes small systems for 12 volt applications. I use them for walk behind fert spreaders. Basically what you get is a low volume air pump, switch, hoses, plastic bottle to put the soapwater in, and the hose and emitter nozzle. I think they go for $150 or so.
Dave Sherburne NY
03-22-2007 07:28:10
Check this http://www.ytmag.com/cgi-bin/viewit.cgi?bd=nboard&th=594858 or this
GWB111
03-22-2007 05:17:29
They are no trouble to make if you have an air scorce. I have made several out of old water heater tanks, you mount the tank vertically, fill it partialy with water and foamer mix,blow air into the bottom of the tank and plumb a hose off the top for the foam. The volume of foam is controled by the volume of air blown into the tank, use a check valve so foam solution doesn't feed back into the air compressor when you shut it off. I use 3/4 hose off the top for the foam with an empty 2 liter soda bottle with a 2" hole cut in the bottom on the discharge end of the hose to make the foam balls larger.
RayP(MI)
03-21-2007 16:15:26
I suspect that you could do something pretty simple with a small electric pump from a garden/lawn sprayer - a small plastic tank and a couple nozzles on the ends of your spray booms.
