246 CORN PLANTER
JOHN PAGEL
03-21-2007 14:20:41
could somebody tell me how the markers worked on this corn planter?
thank you
MLD
03-22-2007 06:18:06
 Re: 246 CORN PLANTER in reply to JOHN PAGEL, 03-21-2007 14:20:41
My ucles has handle/lever that you have to turn to drop the marker on the left or right side when you lower the planter. When the 3 point hitch lifts the planter the markers come up automaticly & lock in place until you hit the lever again. You can plant in 5th gear with his 520 when the land is right. I like those planters.
Hugh MacKay
03-21-2007 16:37:17
John: If it hasn't been altered since new I can. That outside frame that press wheel axle fastens to and has a roller at front. That frame on each side is supposed to pivot at about 1/3 of the way back. As you lift the planter those rollers force markers up. On many of these planters that pivot is seized from fertilizer. The lever for markers at center is designed to latch the marker you don't want going down when you lower the planter. I hope this helps, if not come back and I'll try another approach.
