farmhand accumulator
Tinman13
03-21-2007 10:46:28
I have just purchased a farmhand accumulator that was powered off the tractor hyd. system. It has an open center valve on it and I need it to be a closed center system for a J.D. Did they use a valve with the power beyond plug or do you change the valve? Thanks, Steve
Coloken
03-21-2007 12:55:45
 Re: farmhand accumulator in reply to Tinman13, 03-21-2007 10:46:28
Don't know JD hydraulics at all, but I do know the acumulator. I sugest you power it with a large PTO pump. It needs a large flow and it needs it when it needs it. Has to be enough to "thump" those bales across the bed. Know several people that gave up on them and could not make them work when all they needed was more hydraulics.
