How much hp for a NH 352 mixmill?
John Schneider
03-20-2007 12:22:57
I just bought a nice shape little New Holland mix mill...the 352 model. I am curious what kind of hp I would need to operate it. I have never owned a mix mill before and have always used a belt driven hammer mill. Wondering if the WD45 will make it work or do I need to wait for the 766 to arrive?
JOHN HARMON
03-20-2007 22:12:45
 Re: How much hp for a NH 352 mixmill? in reply to John Schneider, 03-20-2007 12:22:57
If you are hand shoveling Ear Corn ,Shelled Corn,Oats etc. the WD45 will keep up with you,an 190xt would be ideal so a 60-70 HP. Tractor is about right even though a smaller Tractor can get the job done but a little slower. I used both of the above tractors plus some times a D17 ,depending what was available and I could not drag any of them down useing a #12 Aluminum Scoop.
Glenn F.
03-20-2007 14:53:23
The Allis will do it with its tongue hanging out! We've ground a lot of feed with our DC CASE. It's really too much for it, but you use what you have.
Glenn
RustyFarmall
03-20-2007 13:52:43
Your Allis will do just fine. The 766 will get-er-done quicker.
Chester5731
03-20-2007 12:40:58
I have a neighbor yhat ran one with a farmall M without any trouble.
buickanddeere
03-20-2007 12:29:28
Depends on how fine the screen is, how sharp are the hammers, how worn is the ledger plate, air/feed temperature and humidity/moisture.Depends on how many ton you want to grind per hour and what the feed material is.
BarryfromIA
03-20-2007 18:49:39
 Re: How much hp for a NH 352 mixmill? in reply to buickanddeere, 03-20-2007 12:29:28
If you have a real big horse and fill fast, you need to let it mix for a while after it is filled anyway. So take your pick.
John Schneider
03-21-2007 14:20:19
 Re: How much hp for a NH 352 mixmill? in reply to BarryfromIA, 03-20-2007 18:49:39
I just thought of something else though...the wd45 is a 540 pto and the 766 is 540/1000. How can I tell what the mixmill is set at? I suspect that it is a 1000 pto based on the newer JD tractor that the previous owner was using.
Sam in Mi
03-22-2007 06:21:55
 Re: How much hp for a NH 352 mixmill? in reply to John Schneider, 03-21-2007 14:20:19
Look at the PTO shaft on the mill. If it is fine spline where it hooks on the tractor it is 1000, coarse spline is 540.
