Need hydraulic help
Brian Jenkins
03-19-2007 17:06:41
I have an old warner swasey bakhoe attachment that came off a case 450 dozer. I am preparing to mount it on my d4 caterpillar dozer. I plan on powering the unit with a pto hydraulic pump. This hoe is enomous and will dig about 16feet deep. Does anyone know about how many gallons per minute pump i need?
Handyman
03-19-2007 19:35:42
 Re: Need hydraulic help in reply to Brian Jenkins, 03-19-2007 17:06:41
It all depends on how fast you want to run the hoe. I have a JD 510 TLB with the main boom cylinder being a 6 inch diameter, it is fed oil by a large 6.0 cu in displacement pump (60 gal min) @ 2800psi this gives it a fairly quick travel but a pump of that size will have a large price tag on it. a smaller pump will work for you it will just be a lot slower to operate but if you are not in a hurry speed isnt allways needed. the main thing you need to be concerned about is how much pressure you will be needing to get the job done.
Bob Plumadore
03-19-2007 17:33:13
why not run it off your tractor hydraulic, most d4d came with a deactivated 3 valve if not it is not proplem to install a deverter.
