Kinze vs Deere Bean meters
RossMN
03-18-2007 10:37:03
I was wondering witch soybean meters was better/accurate, Kinze or Deere? I have a chance to buy some used ones for $65 a row and would go through them before planting. I have a Deere dealer and a Kinze dealer in the area so parts arn"t an issue. They will be going in a 7000 8-30" planter
JOE-ILLINOIS
03-18-2007 18:13:50
 Re: Kinze vs Deere Bean meters in reply to RossMN, 03-18-2007 10:37:03
Hi, I run both and I think the new radial meter is more accurate, I have only used them for one season and the book says there is a brush in them that needs checked, I think it is about $4.00 on the other hand the kinze meter is far better than the old seed cup but the upper and lower brushes are $8 and $14, the wear strip is $10 but depending on acres you don't change them every year. I will use both again this year, if you can buy a radial meter for same money I would buy radial meter, hope this helps,thanks joe
I love farmalls
03-18-2007 16:09:41
The new radial seed meters are really accurate because you can select the seed size and go by the chart.
IaGary
03-18-2007 13:13:42
No comparison, the Kinze are by far more accurate then the old JD meters. Not familiar with the new JD.
Gary
