Ferguson 2-16 Plow Coulter Bushing Play
Chuck Lombardo
03-14-2007 08:16:53
I am a member of TractorByNet and posted this question. It was suggested to ask it here. Thanks in advance.
I just finished putting new shears on an old Fergusion 2-16C plow. I also replaced one of the coulter bushings. After reassembly, both colters move side to side about 1/4 inch, sliding on the bushing until it hits the hub cap on that side. That is both, regardless of new or old (original) bushing. There are no missing pieces. Why would the original setup have so much slack? Could the original parts (1954) have worn down in a way to create that slack? BTW, the new bushing and the original are the same length. Seems to me I should grind the bushings shorter to take out some of the sideways play. Is there a reason they slip back and forth along the bushing? The grease just comes out the gap at the hub caps.
Thanks very much.
Chuck
[email protected]
Scott pa
03-14-2007 17:49:56
 Re: Ferguson 2-16 Plow Coulter Bushing Play in reply to Chuck Lombardo, 03-14-2007 08:16:53
The side of the hub may be worn away leaving the gap.
