PTO on CUB tractor
Neepneep77
03-12-2007 17:03:36
Is there an adapter or something that I can get to go from the 10 or 11 spline pto to the standard 6 spline for todays implements? Can anyone help me?
RN
03-12-2007 17:54:13
 Re: PTO on CUB tractor in reply to Neepneep77, 03-12-2007 17:03:36
Cub PTO? Rick is right on the speed and rotation- However, previous postings have noted adaptor to change direction/reduce speed/offset to right for use on other equipment. Possible Woods mower setup with extra belt pulley for one of their center mount mowers, another mentioned for use with pulled behind mower and as a PTO power source for some other equipment- a geardrive with about 3 to 1 reduction. Rhino? IHC didn't make it, the other brands equipment either made it or sold someones special design with their equipment. RN
RickB
03-12-2007 17:11:55
 Bad news in reply to Neepneep77, 03-12-2007 17:03:36
The only help I can give is to tell you your Cub's PTO turns in the wrong direction and at the wrong speed to be compatible with standard implements designed for 540 RPM operation. Cub PTO's turn at crankshaft speed in the direction of crankshaft rotation. Only implements designed for Cubs will work satisfactorily.
