stub gaurds
jb 46
03-12-2007 06:52:52
i have pt-10 have regular gaurds on had alot of problems with far end picking up sod (hanging up on gaurds)and plugging. going to a stub gaurds at the last 4 or 5 gaurds do you think this would help this problem? new sickle last year only do 15-20 acers.
Gerald Michaels
03-12-2007 16:49:06
 Re: stub gaurds in reply to jb 46, 03-12-2007 06:52:52
Check the end guard,there is suppose to be a metal piece covering the tip of the guard. If this gets wore off it will plug up often.
JMS/MN
03-12-2007 08:27:25
If the far end is running into the ground- have you checked spring tension? When I bought my discbine the dealer set it up according to the drawbar height of the tractor I was to use, as well as ground speed. Higher speed creates more pulldown of the header, so springs need to be tighter. Op manual tells correct lift (lbs) that header should require.
Doug in IL
03-12-2007 07:08:48
I think that may help solve your problem. Stub gaurds are a night and day difference from the full gaurds. Of course, if you have any rocks they are not for you. If it was me, I'd change the whole machine over to stub gaurds.
