Vermeer R21 behind JD 4010 - How to slow down hydr
TimS in Mo
03-09-2007 06:52:12
I bought a fixxer upper R21 ( mostly needed a bunch 140+ rake teeth and a couple hydraulic hoses, and a lot of lubing etc ) that I was wondering how to slow down the hydraulic flow coming from the 4010 scv since they didn't have the flow control knobs.
I know I could put a flow restrictor in place, I also thought of making a flip over bracket that would hold the second scv lever in the 'slow extend' position as well.
Any other ideas before I reinvent the wheel on how to slow the hydraulic flow from a closed center hydraulic system thru those motors on the rake?
Oh, and just for fun and because the rake was rusty in a lot of spots, we painted it glossy JD green with gloss jd yellow wheels. I'm going to get some John Deere stickers for it and a made up model number like 699 and slap on it just for fun. Vermeer makes the newer and bigger R23 rake for JD as the 705 so I figured what the heck.
It actually looks so good the paint crew ( father in law, my dad, and my wife ), want me to pull the Vermeer 605 H in the barn, clean it up, strip the stickers off and paint it green as well - which I imagine we will do as well as its a bit rusty in spots and we have lots of gloss JD Green paint.
Gerald J.
03-09-2007 08:56:07
 Re: Vermeer R21 behind JD 4010 - How to slow down in reply to TimS in Mo, 03-09-2007 06:52:12
There's a flow control adjustment on the remote valve that's mounted on the fire wall. Its adjustment is covered in the shop manuals.
Gerald J.
TimS in Mo
03-09-2007 08:59:39
 Re: Vermeer R21 behind JD 4010 - How to slow down in reply to Gerald J., 03-09-2007 08:56:07
Thanks Gerald, I thought one had been mentioned but I didn't see any mention of it in the owners manual.
Do you know if the I&T (thin) manual has that section or not?
I'm at work and won't be able to check until later.
Gerald J.
03-09-2007 10:43:07
 Re: Vermeer R21 behind JD 4010 - How to slow down in reply to TimS in Mo, 03-09-2007 08:59:39
Yes, its covered in the I&T, paragraph 137 or 138, picture 96D.
Gerald J.
