Old JD Plow Shares..
BushogPapa
03-08-2007 19:39:20
Went to swap shares from one old 2 bottom 14" to the other, better one, and they are different...!!
The ones I have been using are getting pretty thin...can I find a set, or is it better to try and get these sharpened and built-up..?
The reason the other set won't fit is that the Draw-bolt pin is in a wider position... I would change Frogs, but the bolt pattern in the mouldboards is different..!! Any suggestions..?? Thanks..! Ron. In Ohio...
Charlie M
03-09-2007 11:40:28
 Re: Old JD Plow Shares.. in reply to BushogPapa, 03-08-2007 19:39:20
I have a 3 bottom JD plow with Syracuse bottoms (don't know if yours are the same) but I finally swapped out the whole thing for Model 314 bottoms. Now I can go to Tractor Supply and buy bolt on plow points anytime. Cost for 3 is less than one of the old type and don't break as easy.
El Toro
03-09-2007 09:06:38
You can call Plow Blades at 1-800-383-PLOW to see if they have a replacements. Hal
PS: Empire Plow in OH has them too, but they may not sell directly to you, but may give you the name of distributor. 216-441-4709 or email them at [email protected]
riverbend
03-09-2007 05:53:12
Take you old shares to your JD dealer. Real replacements are expensive (~$100 ea.), but the JD throw aways are fairly cheap.
55 50
03-08-2007 21:54:26
I got new 16 inch shares for a model 44H from Deere, if I remember correctly, in late 2005. But as "fumble farmer" said "not cheap".
fumble farmer
03-08-2007 20:15:31
www.Balsters.net most likely has shares .Not cheap thoug.
