Disk Harrow for VAC Case Tractor
Cary Kennedy
03-07-2007 22:09:40
I have a 1952 Case VAC,tricycle Tractor,I am guessing around 20 hp. Skids logs up to 36"-10' long,bushhogs ok in first gear with 5' deck.
What would be the maximum size disk harrow suitable for this tractor? Total width? Number of disks?
thanks in advance,Cary
daulclan
03-08-2007 06:55:24
 Re: Disk Harrow for VAC Case Tractor in reply to Cary Kennedy, 03-07-2007 22:09:40
We have an old 46 VAC. It play's with a 6 foot drag disk here in Kentucky. Ours has about 23 HP with oversized pistons @ the overhaul. In most cases it will work side by side with its contempory the H Farmall even with the 28 inch rims.
daulclan
03-09-2007 06:59:13
 Re: Disk Harrow for VAC Case Tractor in reply to daulclan, 03-08-2007 06:55:24
Notice, I said in most cases. I'd say our old VAC would pull an 8 foot drag okay in northern types of soil. It was said that They would pull 3 bottom (12 inche) plows in northern Indiana but not here in KY with the clay soil. Only thing the H has up in the VAC was rim size.
El Toro
03-08-2007 07:56:29
We pulled an 8-foot Case disk with an H Farmall and used a drag behind sometimes. This wasn't very hilly ground and that would probably make a difference. Hal
daulclan
03-08-2007 06:55:20
georgeky
03-08-2007 12:04:49
 Re: Disk Harrow for VAC Case Tractor in reply to daulclan, 03-08-2007 06:55:20
That must be a good one. I to live in Ky. I have my grand pa's VAC and a H and the H will run cicles around my VAC. I have a real good set of two row ciltivators that came new with the VAC. My grand pa thought it was the greatest thing since sliced bread. I suppose it was compared to the horses he used prior to the VAC.
El Toro
03-08-2007 06:12:54
I would recommend the 6-foot disk too. Hal
georgeky
03-08-2007 05:40:27
A VAC is only about 12 HP, but they are good little tractors a 6 foot harrow will work good it should have around 24 disc. It may puul a 7 foot in some cases, but I would go with the 6.
