IH 241 round baler
wi tom
03-07-2007 17:06:05
Anyone have ant advice or comments on this baler? Just picked one up and would appreciate any advice \
thanks
Rog in IA
03-11-2007 18:21:49
 Re: IH 241 round baler in reply to wi tom, 03-07-2007 17:06:05
I had a 241 for many years. the double spring does help. Two weaknesses i see is it has very light bearings and the expensive bottom belt if you have to replace.
johns48jdb
03-07-2007 18:31:27
the only way i could get mine to start a bale right was to end up on one side of the windrow, tie the bale off and then, as quick as i could by zig zagging, get some hay all the way across the width of the baler. i think that a lot of the problems with the bale density was related to the power of the tractor hydraulic system in keeping pressure on the belts. we could put down pressure on the bailer with the hydraulics a couple of times during the forming of the bale and it would do better. may have been problems with the hydraulics on my ih 574.
georgeky
03-07-2007 20:46:21
 Re: IH 241 round baler in reply to johns48jdb, 03-07-2007 18:31:27
That is the nature of the beast and a lot of other rollers to. I bought a 510 JD last year and it is the same way. There is nothing wrong with your tractor these rollers do not roll a tight bale. It does help to have the double spring kit.
georgeky
03-07-2007 17:17:43
They dont roll the tightest roll you ever seen but they do hold up good. I have a 241 and a 2400 that we bought new in 1980 it has rolled thousands of rolls. They are very cheap around here 200 dollars will usually buy one at auction. There is a double spring kit you can install if it don't already have one that will tighten up those rolls some. I have a extra spring kit if you need it email me.
