Burch Disk
Donald In Ky
03-05-2007 22:27:17
I just got hold of an old burch disk. Did they make a disk that had no ball bearing in the disk bearing look like its metal to metal. i seen wood box bearing but not metal to metal.. just wondering if i could put ball bearing in it. thanks for the help
Leroy
03-06-2007 16:13:26
 Re: Burch Disk in reply to Donald In Ky, 03-05-2007 22:27:17
We had one with the white iron bearings, that is the metal to metal type, most makers used them before the ball-roller bearings came into use and as option for years after, and I dought you could change one over, you would have to not only find a bearing but a different spool to fit the new bearing plus a new bearing hanger. Those bearings I have never heard of one wearing out, They do like to squeel-howel even if kept full of grease
BCnT
03-06-2007 07:20:33
CRS is actin up this mornin so i cant recall proper name for that metal to metal bearing but theyre pretty common on disks...last a loooonnnnnggggg time if ya keep em greased and most any tractor supply will have replacement parts
georgeky
03-06-2007 07:10:19
Donald I have a Burch disc and it has bearings in it .
