Nine Inch Implement Tire Needed.
farmallhal
03-04-2007 16:11:03
I am needing a 4.00 X 9" implement tire that is like the original low profile style. I have seen one in a catalog but it is almost 18" in diameter when inflated and my original is only 15". I think the original one I need to replace is made by the "blimp company". Just wondering if anyone has been tire shopping for a similar tire recently and what have they found. These tires are commonly used on hay rakes, trailing mowers, plows, etc. Any suggestions or comments will be appreciated, Hal.
Glen in TX
03-05-2007 07:15:34
 Re: Nine Inch Implement Tire Needed. in reply to farmallhal, 03-04-2007 16:11:03
A few others places to try but no guarantees you know.
tuckertire.com
nebraskatire.com
tiretown.com
farmallhal
03-05-2007 13:11:53
 Re: Nine Inch Implement Tire Needed. in reply to Glen in TX, 03-05-2007 07:15:34
Glen, thanks for the web addresses and I will check them out, Hal.
Jimmy King
03-05-2007 05:25:18
Don"t you wish big Sam was still alive, Hal or even better his Dad.
farmallhal
03-05-2007 13:17:22
 Re: Nine Inch Implement Tire Needed. in reply to Jimmy King, 03-05-2007 05:25:18
Jim, I stopped by Sam's Tire this morning. I don't know if you knew Norman Snodgrass but he is the manager now even though it has been taken over by some larger company in St. Louis. Norman has worked there from probably about the time they open in late 1940's or early 50's. He is well past 70 now and in fact they had a special event to celebrate his 50 years of swervice a few years ago. Talked to Norman and he said all he shows available through their sources is the Carslisle but he knows Titan used to make them if I could locate a pair. Have a good and safe one, Hal.
Hugh MacKay
03-04-2007 19:56:12
Hal: I have a Miller catalogue in front of me and they do show a couple of 4.00x9 tires. They will be able to tell you outside diameter when inflated.
farmallhal
03-05-2007 13:10:11
 Re: Nine Inch Implement Tire Needed. in reply to Hugh MacKay, 03-04-2007 19:56:12
Hugh, I saw one in their catalog I picked up at last year's RPRU and that is where I got the tire diameter when inflated. I am looking for a low profile style like the original if they can still be found. Thanks for the response, Hal.
georgeky
03-04-2007 19:34:30
Hey Hal. What happened to Miller tire?
farmallhal
03-05-2007 13:20:05
 Re: Nine Inch Implement Tire Needed. in reply to georgeky, 03-04-2007 19:34:30
Miller Tire is still going and active but all they have to offer is the Carlisle brand and I'm trying to locate the original type which were a lower profile tire, Hal.
old
03-04-2007 19:11:50
Hal, do a search for Kelsy tires here in Camdenton he will have or know where to find them but hold on to your back pocket if he has them becasue they will not be cheap. Shoot he can probably make you a set since he buys most of the old tire dies when they stop makeing that type of tire. I worked for him for awhile and he could get almost any tire you wanted but you also pay the price for them. His name is John Kelsey and he does antque tires for cars and trucks etc. You want a tire for say a 1929 packade and he will have it or he will make it for you
farmallhal
03-05-2007 13:25:57
 Re: Nine Inch Implement Tire Needed. in reply to old, 03-04-2007 19:11:50
Rich, thanks for the information and do you have a phone no. for contact or is it available on the web yellow pages? I will certainly contact them and see what they can offer but sounds like I may have to become employed again with that route. Thanks for your response, Hal.
P.S. I'm still cleaning up ice storm damage to the trees along our driveway. Haven't gotten in the yard yet as it is still too soft for a tractor and hauling it away. Know you have the same mess to deal with.
old
03-05-2007 14:25:15
 Re: Nine Inch Implement Tire Needed. in reply to farmallhal, 03-05-2007 13:25:57
You should be able to do a web search for his company. or try looking for antique tire dealers since thats what he does sort of. He owns most of the dies for the older tires
RayP(MI)
03-04-2007 16:53:04
Replaced the trailing wheels (tires) on my 3pt hay rake with utility trailer tires. Don'tremember the exact size, and rake is in storage at another farm. Check with any reputable tire dealer for sizes available.
farmallhal
03-04-2007 16:58:18
 Re: Nine Inch Implement Tire Needed. in reply to RayP(MI), 03-04-2007 16:53:04
Ray, what kind of hay rake and model no. do you have as I restoring one at present. Just curious as to what other 2 pt. and 3 pt. hay rakes are still out there. I've learned more about hay rakes in the past year then I thought possible. My email is open if you want to "chat" off the forum. Thanks, Hal.
R Wyler
03-04-2007 16:42:46
Carlilse should make one that size>Link
farmallhal
03-04-2007 17:03:54
 Re: Nine Inch Implement Tire Needed. in reply to R Wyler, 03-04-2007 16:42:46
Thanks for your response and I knew that Carlisle made one that size because it is listed in the Miller Tire catalog. I called them and that is the one which is 18" in diameter inflated. I would like to find something closer in height to the other one. I'll go by the tire dealer tomorrow and see what they can locate but not many choices in our small rural local town. I'll certainly give their website a look see. Thanks again for your responses, Hal.
R Wyler
03-04-2007 16:45:09
One other thing I should have added and meant was they make rib implement tires in that size range I bought one about that size for my Deere #5 sickle mower it was a Carlisle rib implement I think it was an 8 incher and around 4 inches wide. So you shouldnt have any problems getting one.
James Howell
03-05-2007 10:56:15
 Re: Nine Inch Implement Tire Needed. in reply to R Wyler, 03-04-2007 16:45:09
Carlilse makes a 4.00x9 tire. I recently bought one for my JD #5 sickle mower.
farmallhal
03-05-2007 13:06:31
 Re: Nine Inch Implement Tire Needed. in reply to James Howell, 03-05-2007 10:56:15
James, If you have mounted your tire on the wheel already could you measure the full diameter of the tire as inflated? My original tire is only about 15" in diameter when inflated and someone told me the Carlilse would be 3" greater. Also what type of grooves or thread does this tire have as my old original one is just straight grooves like on implement tires. Thanks for your response to these questions, Hal.
James Howell
03-05-2007 14:50:32
 Re: Nine Inch Implement Tire Needed. in reply to farmallhal, 03-05-2007 13:06:31
Hello Hal. Both of my mowers are 135 miles away at my farm in NE Texas. I will not be going back until Friday.
After looking at an 18� ruler, your 15� diameter measurement sounds right.
If memory serves me, there are 3 ribs and 4 grooves.
Respond to R Wyler in a previous post. He stated that he bought one about that size for his Deere #5 sickle mower it was a Carlisle rib implement. His mower may be close at hand for a measurement.
Sorry I couldn�t be more help.
farmallhal
03-05-2007 17:10:44
 Re: Nine Inch Implement Tire Needed. in reply to James Howell, 03-05-2007 14:50:32
James, I stopped at one of my favorite tire places this afternoon - they advertise "If it's round, rolls and is rubber we have it". Actually they had a 9" Carlisle on their rack. This guy knows his tires and just doesn't have a catalog to look at and he told me Firestone still makes what I was looking for in a 4 ply tire. He made a quick call and yes they are available so that is the route I'm headed. Thanks again for your responses, Hal.
