Woods mower
Terry DeBoer
03-02-2007 16:44:13
We have a 60 inch Woods mower on our Allis B. It is our main mowing tractor for the pastures. I've been working on it, fixing all of the leaks and getting it ready for this summer. I was going to replace the blades because they were starting to crack. I tried using an impact to get the bolts off that hold the blades on but it wouldn't budge. So then i decided to take the whole spindle off so I could put them in a vice. I have all of the spindles removed currently. So i put one in the vice and put a pipe wrench on it so the shaft wouldn't turn and then put a breaker bar on the bolt with a 3 foot pipe extension. Of course the bolt didn't come out; I ended up snapping it off. The bolt did have never cease in it. Is there any thing that I can do to get the other two blades off without snapping the bolts. Or should I just snap them off and replace the shaft that goes the hub. Any tips will be appreciated.
Terry DeBoer
03-03-2007 14:53:02
 Re: Woods mower in reply to Terry DeBoer, 03-02-2007 16:44:13
This one does have left hand threads. The other two came out easier when i turned it the right way. Luckily the bolt that I snapped I was able to get out without even having to weld a nut to the remaining bolt. I just took a chisel and hammer and hit the little burr from where it broke and it started moving. I got really lucky there.
Terry DeBoer
03-03-2007 14:52:36
Duner Wi
03-03-2007 10:44:22
My Woods RM 59-1 has left hand threads and air wrench works getting it apart.
banjo
03-02-2007 21:24:43
My woods L59 has left hand threads and they are tough to get loose. Depending on which way the blades turn should tell you which threads you have.
Big Mike
03-02-2007 20:16:54
old is right. Some of the older Woods mowers did have left-hand threads on the blades. We've had two in the shop over the years, and at times, could be real BEARS getting then off!!!!
old
03-02-2007 17:12:07
Well this is just a guess but some of them have left hand treads and if so yep you will brake the bolt before it comes off if your tring to turn it the normal way. BTDT on more then one mower deck and its a bit(h
