Hammer mill ???
old
02-28-2007 20:55:28
I've got an old hammer mill here and the belt pulley is long gone. Could I hook this up direct to a PTO shaft on a tractor and if so would it spin to slow or to fast?? I think its an old IH hammer mill.
Thanks
Loren in MN
03-02-2007 20:32:21
 Re: Hammer mill ??? in reply to old, 02-28-2007 20:55:28
I have a Gehl hammermill that is pto driven. Since we've just gotten 2 feet of snow, I'm not able to make actual measurements, but checking a photo I have, the pulleys seem to be about 20 inches on the pto shaft and 5 or 6 inches on the mill. Email me for photos.
DRL
03-01-2007 13:00:04
My John Deere 10A hammermill is rated to turn at 3200 RPM. I would think that directly connecting the hammermill to the PTO shaft would be too slow. I have seen some hammermills that were set up like a squealer rotary mower. They had a car or truck tire and wheel connected to a PTO shaft, with the wheel touching the belt pulley. This would get the RPM's you would need.
WCS
03-01-2007 23:25:58
 Re: Hammer mill ??? in reply to DRL, 03-01-2007 13:00:04
Arts-way Mfg. made an early grinder-mixer with that type of drive. I think they called it a "1956 Model", maybe came out that year.
old
03-01-2007 13:32:41
That would maybe work if, it still had a belt pulley but its long since gone and fell apart years ago, it was so bad if it was still there it wouldn't be for long if I did that because it would have flown apart
kurt Dittmer
03-01-2007 10:35:58
here's one E Bay:
http://cgi.ebay.com/FLAT-BELT-PULLEY-FEED-GRINDER-MILL-GAS-STEAM-ENGINE_W0QQitemZ330093910271QQihZ014QQcategoryZ63945QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Leroy
03-01-2007 06:51:14
Old, this is from a 1951 Wards farm catalog for their mills. Rotor 2400 RPM under load. Pto conversion kit for PTO 6 90" V belts from 22" flat faced pully on PTO shaft to 5" OD V belt pully on mill and at that time all PTO's were approximatly 540 RPM.
J. Stephen
03-01-2007 05:52:31
Mark, Any chance of posting a photo of the mill set up for pto? I'm trying to convert a Fairbanks Morse model 40 at this time. Thanks!
Mark
03-01-2007 17:40:25
 Re: Hammer mill ??? in reply to J. Stephen, 03-01-2007 05:52:31
J.Stephen,
If I knew how to get the pix up here...it would be no problem...and everybody could use it for future reference. In the meantime, you can email me and I can send photos direct to you.
IaGary
03-01-2007 04:18:49
Most old hammer mills that I have seen with the belt drive have a pulley about the same size as the tractor pulley. Or one to one ratio.
What is the speed on a belt pulley. Is it faster than PTO speed?
Gary
paul
03-01-2007 09:22:59
 Re: Hammer mill ??? in reply to IaGary, 03-01-2007 04:18:49
A pto is generally 540 rpm. New big or tiny tractors might have 1000 rpm as well. All shaft couplers are the same diameter, so rpm is a useful number to compare.
A belt pulley can be different sizes on different tractors, so rpm is a worthless measure - big or little pulley will give you a very different speed. So they are rated at feet per minute. Sorry I forget wat the standard fpm is.
--->Paul
paul
02-28-2007 21:35:12
Too slow.
--->Paul
Mark
02-28-2007 21:13:34
old,
For what it's worth....the hammer mill I have is PTO driven and the PTO shaft pulley is about 16" in diameter and has 5 V belts on it...this runs to the hammer shaft and that pulley is about 5". So, this should mean the PTO shaft speed is INCREASED about 3X unless my figuring is screwy. That would seem to indicate that direct drive would be too slow if anything. Consider too, the tractor belt pulley is probably 9" or 10" and the mill pulley 5" or 6"...again making the mill turn faster than the drive pulley.
