605c vermeer roller
Big un
02-28-2007 17:47:43
What is ya'lls opinion of this baler? Pro's / Con's.Maybe able to buy one cheap if it is worth fooling with.
Thanks
Big un
HayDR
02-28-2007 21:45:30
 605c vermeer roller in reply to Big un, 02-28-2007 17:47:43
605C balers are always available at auctions for $300-$500. They are 30+ years old and are a closed throat baler. One major repair and they will be junked. The still will bale hay but time has caught up with them.
KEH
03-01-2007 15:11:42
 Re: 605c vermeer roller in reply to HayDR, 02-28-2007 21:45:30
Hay Dr, wasn't the C baler the one that the top front roller had a tendency to come loose and fly at the operator? I think I've seen some with a guard welded around the ends of the roller to prevent that.
Anyway, I would try for an open throat baler made in the 1980s and let the C go.
KEH
2t2@ia
02-28-2007 21:27:11
 Re: 605c vermeer roller in reply to Big un, 02-28-2007 17:47:43
Joe is right. If the product is a little too moist or a little two dry, the 605C can give fits. If everything is just right, they work well.
joe-etx
02-28-2007 20:04:12
well if you need 200 or 300 bales a year it will work.its not a i will go home from work and bale some hay baler , you need to time things perfect. its a closed throte baler,hard to start a bale.i live in east tx and will give you one if you want it worked good when last used.Cs were from early 70s mines a 74 i moved to a F and up from there.thay are a fun baler and have thought many a times of giving mine anothre work out. joe
MaverickM23
02-28-2007 18:29:11
Don't know how old the 605C is but we have a Vermeer 504C. Baler works ok, I have tryed to get it to make a tighter bale but it won't and the pickup isn't the best. If the bales are left outside they start to droop and fall apart pretty easy. If you are putting them under a shed you might be alright. We bought a Hesston 530 and it works like a champ, 4x4 bale but very simple and easy to use and makes a very tight bale.
