How does tounge on disk go?
Michael Price
02-26-2007 06:55:08
On the disk Im fixing up I was wondering how the tounge went. On one side there is a round hole for the pin and the other side has a slotted hole. I forgot which side was up before I took it apart, I think the round hole was up. Or does it matter what side goes up?
evielboweviel
02-26-2007 13:57:07
 Re: How does tounge on disk go? in reply to Michael Price, 02-26-2007 06:55:08
round hole up
Ron
RePete
02-26-2007 12:02:00
Sorry I can't help you with your machine.
Just wanted to warn folks not to put their tongue on a disc at least not in the winter time.
I did it once on my grandad's disc when I was about 6 or 7. Froze right on. It's hard to yell for help too when your tongue is stuck down. Sheesh!
Grandma had to come out with a jug of hot water to get it unstuck.
Bled all afternoon.
Don't put your tongue on a disk.
Pete
K-Mo
02-26-2007 09:03:56
I assume you are talking about the hitch pin holes. I would say the round hole up.
If both hitch holes and the drawbar hole were all 3/4" with a 3/4" pin, it would bind up when going over uneven ground. By slotting the hole, it allows some vertical movement without binding.
That's my 2-cents.
Michael Price
02-26-2007 08:47:30
Here is a pic of the disk
Link
Im not sure how to get a pic up on here. What Im wondering in the whole where the pin goes through. One hole is round and the other is slotted for some reason. I know its not wobbled out, it was made that way.
paul
02-26-2007 20:56:35
 Re: How does tounge on disk go? in reply to Michael Price, 02-26-2007 08:47:30
third party image
Put the picture link (NOT the page the picture is on, but the pic address itself) in the Optional Image below.
Hole to the top, slot to the bottom. As mentioned, it is for some give as you go over uneven ground. Your pin should be close to the same size as the round hole, needs some play at the bottom to allow flex or it will want break something.
--->Paul
55 50
02-26-2007 07:49:33
Need more info. What kind of disk? What kind of tongue? Angle iron? Channel iron? Pipe? A photo would be a great help. Get a manual for it as further help!!
El Toro
02-26-2007 07:35:53
I wonder why there's a slot in the tongue. I think I would leave it as you have it now. Hal
