plow question time is running out
Larry in GA
02-23-2007 11:29:55
Plow day is only 14 days away and counting.
Question is the lift rod on a two point fast hitch pinned or flouting when plowing with a fast hitch two bottom plow. plow day is in Ray City GA. the 10th of march and everyone is invited (no plows bigger than three bottom please)
The location is on hwy 64 at the city limits We will start setting up and telling stores 8- 830 -9 AM and start plowing about 1230 1 O:clock
As of now there are also two mule teems planning to be here. It should be a fun day. LO
Thack
02-24-2007 10:02:12
 Re: plow question time is running out in reply to Larry in GA, 02-23-2007 11:29:55
If you mean the lift links they are in the rigid position when plowing.
Larry in GA.
02-24-2007 10:28:36
 Re: plow question time is running out in reply to Thack, 02-24-2007 10:02:12
The one that hooks to the top of the cylinder to the lift point on the fast hitch
Larry
ShepFL
02-23-2007 18:53:35
Is this the Ray City N of Voldosta? If so you are about 2 hrs away. I would like to come up there. I have a 2 bottom disk plow and and 2 bottom moldboard plow.
I will see what the Home Minister has to say. I am planting spuds this wx!
Larry in GA
02-24-2007 02:33:40
 Re: plow question time is running out in reply to ShepFL, 02-23-2007 18:53:35
Yes the Ray City 16 miles from Valdosta. Come on up we would love to have you. I will be the one with the wide brim hat withe the super C
Hugh MacKay
02-23-2007 11:48:54
larry: Mounted plows always have to float. if they didn't every time one went through the slightest hollow, the plow would lift rear wheels clear.
IaGary
02-23-2007 14:00:33
 Re: plow question time is running out in reply to Hugh MacKay, 02-23-2007 11:48:54
We expect pictures when you get back from the plow days.
