tandem disk for a 4230
gorilla
02-21-2007 08:16:06
I need a disk for my 4230 (100 hp). I have used a 20' kewannee disk several times and it pulls just fine except that I lose traction in loose soil the 2nd time around. I found 3 disks in my price range. IH 475 18' non fold. 19" disks IH 475 Manual fold (has springs) 19" Disks
Krause 1404 22' hydraulic fold 20" Disks
They all seem to be clean and in pretty good shape with no welds. Bearings look ok. The Krause seems to be a little heavier disk. They all have standard disks (not cone shaped) The disks on the krause seem to be a built a little thicker than the IH disks. I will be using it in blackland. 1. Which disk would be the best match for my 4230? 2. I dont have ballast in the tires or weights on it...if I added ballast would the 4230 pull the 22' disk ok?
3. The IH Disks seem a little thinner but smooth, no chunks out of em..How do I gauge how worn they are? Thanks, gorilla
Tx Jim
02-21-2007 13:00:20
 Re: tandem disk for a 4230 in reply to gorilla, 02-21-2007 08:16:06
gorilla,out of the three you named depending on price and condition I would select the IHC 475 manual fold. Second time over if traction was a problem then fold wings up. IHC made some very good tandems in that vintage. Tx Jim
Gorilla
02-21-2007 18:01:25
 Re: tandem disk for a 4230 in reply to Tx Jim, 02-21-2007 13:00:20
Thanks. That the one Im leaning toward.
paul
02-23-2007 21:58:33
 Re: tandem disk for a 4230 in reply to Gorilla, 02-21-2007 18:01:25
Duals and ballast would be your friend.
I'd lean towards that disk as well, being able to fold it. IHC had nice disks.
--->Paul
Don-Wi
02-21-2007 23:31:42
Do you run duals? If they have any kind of tread at all they can help a great deal with spinning out. Also a bit of weight if you don't have it already is pretty much a must for tillage work like that.
Donovan from Wisconsin
