Plowing Methodology Question
Tommy D.
03-08-2000 06:02:44
Since it is spring (almost - hope this doesn't get us another March blizzard like '93!) here in N. Ga. it is time to turn and disc the old garden. My garden spot is triangular, with the sides equal in length at about 200'.
For the past few years, when I turned the ground over with my 2 bottom (flat) plow, I would start across the middle for the first pass. I would then turn around and go the other direction, turning back into what I just turned over. From here, I would just widen this with each pass, turning the ground to the inside so as to leave the last furrows on the outer edges of the garden. This has worked, but leaves a humped mound where the first 2 passes back and forth were made for the length of the garden. It also leaves furrows on the outside edge which washes during a hard rain.
My question is :
Since this area is triangular and not square, could I start on the outside edges, turning the ground outward and work towards the middle? This would leave a small indentation in the very center, but maybe the disc would fill most of this up.
I hope I explained this well enough be be understood.
All guidance here is most welcomed.
Thanks,
Tommy D.
john d
03-08-2000 14:42:55
 Re: Plowing Methodology Question in reply to Tommy D., 03-08-2000 06:02:44
The previous posts are on target about alternating the direction of plowing, and so is the one about fall plowing being an advantage if you have to turn on the plowed ground.
Now for my 1.5 cents worth... I'm lucky enough to have a rectangular area. That simplifies things. I can also turn on the un-plowed grass area that surrounds the entire garden plot. I plow it all 1-way (South this time) one year, the other way the next year. This way I have a furrow at one side, a slight ridge at the other, and neither is a big problem.
Some plows (especially the longer ones) don't like to turn as easily one way as the other. Your 2-bottom size shouldn't give you much trouble, but the turn radius in a given direction close to a fence may be a consideration.
Tim (UT)
03-08-2000 08:41:09
Well, what you might do is plow one way one year and the other way the next year.
The part that you have in the center (described above) is called a back furrow - that's where you have the hump. The furrows on the outside are called dead furrows.
So, this year, just drop the plow down so your wheel is in the dead furrow and plow the other way. Yes, you'll end up with a dead furrow in middle, but next year you can plow it back.
Other other option is to plow the entire garden one way. That would entail either backing up to plow the next furrow, or turning around... There are two-way plows made that have two sets of plows going each way so that you can just go back and forth.
Tim
Gerald J.
03-08-2000 06:09:38
You should alternate starting at the middle and starting at the edge. Disking across the valley at the middle will begin to level it, though a little finesse in plowing that last pass shallower makes leveling easier. Its harder to level up after 3x18's but I accomplish it close enough.
Gerald J.
ADfm(AR) Alternate
03-08-2000 06:27:36
 Re: Re: Plowing Methodology Question in reply to Gerald J., 03-08-2000 06:09:38
You can break the ground as you described and yes there will be a swag in the center. It can be worked in to some degree by disking. Then next time break toward the center and the next time toward the sides that way it even out the ridge being formed in the center by continually breaking toward the center.AD
Gerald J.
03-08-2000 08:36:45
 Re: Re: Re: Plowing Methodology Question in reply to ADfm(AR) Alternate, 03-08-2000 06:27:36
Isn't that what I said?
Gerald J.
Burrhead
03-08-2000 08:45:14
 Re: Re: Re: Re: Plowing Methodology Question in reply to Gerald J., 03-08-2000 08:36:45
Naw I don't think that's the answer you gave Gerald. Go back and read it again. AD did'nt mean any harm.
paul
03-08-2000 08:11:19
This is the way you should do it.
Note that with the triangle, you will have to turn around on the freshly plowed ground, and this will pack it a bit, quite a bit if it is wet. Just the way things are. Here in MN we often plow in fall, so winter can mellow the ground & it is soft & nice in spring.
--->Paul
